Zum Hauptinhalt wechseln
Lenovo IdeaPad U450 Keyboard Replacement
Was du brauchst
  1. Lenovo IdeaPad U450 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Flip the laptop so it's facing upwards.
  6. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Open the laptop.
  7. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Press the most northern region above F6 and F7 until a bit of your keyboard pops out.
  8. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Use the spudger to pry the top of the keyboard out.
  9. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the wire connecting to keyboard to the laptop.
  10. Lenovo IdeaPad U450 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the keyboard
Abschluss
UMass Dartmouth, Team S7-G1, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S7-G1, Julie Spring 2017
UMASSD-JULIE-S17S7G1
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 286
