Zum Hauptinhalt wechseln
Lenovo IdeaPad U530 Touch Fan Replacement
Was du brauchst
  1. Lenovo IdeaPad U530 Touch Fan Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo IdeaPad U530 Touch Fan Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 2, Bild 2 von 2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 3, Bild 1 von 1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 4, Bild 2 von 2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 5, Bild 1 von 1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 6, Bild 1 von 1
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch Fan Replacement, Fan: Schritt 7, Bild 1 von 3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: Schritt 7, Bild 2 von 3 Lenovo IdeaPad U530 Touch Fan Replacement, Fan: Schritt 7, Bild 3 von 3
    • Remove the six 3 mm screws from the fan using a JIS #1 screwdriver.
  8. Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 8, Bild 1 von 2 Lenovo IdeaPad U530 Touch Fan Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the connecter cords from the fan and remove the fan.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 242
