Zum Hauptinhalt wechseln
Lenovo IdeaPad U530 Touch Motherboard Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-6 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Lenovo IdeaPad U530 Touch Motherboard Replacement, Fan: Schritt 1, Bild 1 von 3 Lenovo IdeaPad U530 Touch Motherboard Replacement, Fan: Schritt 1, Bild 2 von 3 Lenovo IdeaPad U530 Touch Motherboard Replacement, Fan: Schritt 1, Bild 3 von 3
    • Remove all of the screws on the back panel with a Phillips #000 screwdriver.
    • Turn over the device and remove the two screws on the outside of the hinges.
  2. Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use a pry tool or iFixIt Opening tool to separate the back panel from the device.
  3. Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Locate the fan and associated parts. It will be in the bottom right of the computer pictured. It is black and has an extension heading off toward the left.
  4. Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the fan casing by using a PH1 size screwdriver head.
    • All fan screws are attached to the fan apparatus, so do not attempt to separate them after unscrewing them.
  5. Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the black and white wires connecting the fan to the network adapter.
  6. Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad U530 Touch Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Lift the fan straight out of the casing.
Abschluss
Rebekah Harmon
108 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,065
