Einleitung
The motherboard is attached to everything in your device, so it is an intensive process to remove it.
Was du brauchst
Schritt 1 Fan
Achtung: Die Schritte 1-6 stammen von einer Anleitung, die derzeit bearbeitet wird.
Remove all of the screws on the back panel with a Phillips #000 screwdriver.
Turn over the device and remove the two screws on the outside of the hinges.
Use a pry tool or iFixIt Opening tool to separate the back panel from the device.
Locate the fan and associated parts. It will be in the bottom right of the computer pictured. It is black and has an extension heading off toward the left.
