Zum Hauptinhalt wechseln
Lenovo IdeaPad U530 Touch Network Adapter Replacement
Was du brauchst
  1. Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: Schritt 1, Bild 1 von 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: Schritt 1, Bild 2 von 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: Schritt 1, Bild 3 von 3
    • Remove all of the screws on the back panel with a Phillips #000 screwdriver.
    • Turn over the device and remove the two screws on the outside of the hinges.
  2. Lenovo IdeaPad U530 Touch Network Adapter Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad U530 Touch Network Adapter Replacement: Schritt 2, Bild 2 von 2
    • Use a pry tool or iFixIt Opening tool to separate the back panel from the device.
    • Lift the back panel straight up to remove.
  3. Lenovo IdeaPad U530 Touch Network Adapter Replacement: Schritt 3, Bild 1 von 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement: Schritt 3, Bild 2 von 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement: Schritt 3, Bild 3 von 3
    • Remove the black and white wires that attach the fan to the network adapter.
  4. Lenovo IdeaPad U530 Touch Network Adapter Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad U530 Touch Network Adapter Replacement: Schritt 4, Bild 2 von 2
    • Remove the two screws attaching the network adapter to the motherboard.
    • Remove the network adapter by sliding it down out of its connector.
Abschluss
Rebekah Harmon
108 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 397
