Einleitung
Use this guide to remove the CPU of your laptop.
Was du brauchst
Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
Unscrew the screws using a Phillips #0 screwdriver.
Unplug the wireless adapter to fully remove the motherboard.
Use the plastic opening tool to take off the front panel.
Unplug the blue wire to remove the front panel.
Fully remove the front panel.
Unscrew the 9mm and 4mm screws (there is one of each screw).
Unscrew the six screws using a Phillips #0 screwdriver.
After you are done unscrewing them, remove the heatsink.
To take the CPU off you will need to unlock it, use the plastic opening tool to unlock the CPU. Turn it to the left until it is unlocked.
