Einleitung
Use this guide to replace the motherboard of your laptop.
Was du brauchst
Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
Unscrew the screws using a Phillips #0 screwdriver.
Unplug the wireless adapter to fully remove the motherboard.
Use the plastic opening tool to take off the front panel.
Unplug the blue wire to remove the front panel.
Fully remove the front panel.
Unscrew the 9mm and 4mm screws (there is one of each screw).
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
