Einleitung
Use this guide to replace the RAM of your laptop.
Was du brauchst
Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
Using either the plastic opening tool or your finger, push the metal bits keeping the RAM down off of the RAM.
After doing this for both sides, the RAM will pop up, allowing you to take it out.
Fast fertig!
Abschluss
