Einleitung
The Lenovo IdeaPad Y410P uses a standard laptop hard drive, so it is simple to replace. Hard drives are often easily accessed, and this one is no different. This hard drive can be replaced in just 2 simple steps.
Was du brauchst
Slide the left battery lock to the unlock position and release.
Slide the right battery lock to the unlock positon and hold it in place.
While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
Using the Phillips #0 screwdriver, remove the eight 8mm screws that fasten the bottom cover.
Lift bottom cover off using a metal spudger and set it aside.
Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket.
Slide the hard drive out of its seat.
