Zum Hauptinhalt wechseln
Lenovo IdeaPad Y410p Ram Replacement
Was du brauchst
  1. Lenovo IdeaPad Y410p Ram Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Ram Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad Y410p Ram Replacement: Schritt 2, Bild 2 von 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Ram Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Y410p Ram Replacement: Schritt 3, Bild 2 von 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Ram Replacement, Ram: Schritt 4, Bild 1 von 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: Schritt 4, Bild 2 von 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: Schritt 4, Bild 3 von 3
    • Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
    • Lift the bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Ram Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad Y410p Ram Replacement: Schritt 5, Bild 2 von 2
    • Simultaneously pull apart both clips that are holding the RAM module down.
    • When the RAM module is released carefully pull it out.
  6. Lenovo IdeaPad Y410p Ram Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Y410p Ram Replacement: Schritt 6, Bild 2 von 2
    • There is a second ram module under the first one.
    • Repeat Step 5 with lower Ram module.
Abschluss
Nick Torres
580 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 869
