Zum Hauptinhalt wechseln
Lenovo IdeaPad Y410p Screen Replacement
Was du brauchst
  1. Lenovo IdeaPad Y410p Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Screen Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad Y410p Screen Replacement: Schritt 2, Bild 2 von 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Screen Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Y410p Screen Replacement: Schritt 3, Bild 2 von 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Screen Replacement, Screen: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Y410p Screen Replacement, Screen: Schritt 4, Bild 2 von 2
    • Using the metal spudger, pry the screen cover off from all sides.
    • Carefully lift the screen cover up and outwards.
    • Place the screen cover aside.
  5. Lenovo IdeaPad Y410p Screen Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad Y410p Screen Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad Y410p Screen Replacement: Schritt 5, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws from each corner of the screen.
    • Carefully lift the screen up and place it face down on the keyboard.
    • A thick cord connects the bottom of the screen to the computer. Do not tug or remove this cord from the computer.
  6. Lenovo IdeaPad Y410p Screen Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Y410p Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the adhesive tape from the small rectangular connector at the bottom of the screen.
    • Carefully pull the wire connector from the screen connector.
    • Remove the screen.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Nick Torres
580 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 365
