Zum Hauptinhalt wechseln
Lenovo IdeaPad Y500 Fan Replacement
Was du brauchst
  1. Lenovo IdeaPad Y500 Fan Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
  2. Lenovo IdeaPad Y500 Fan Replacement: Schritt 2, Bild 1 von 1
    • Unlike the first lock, this lock is spring loaded and must be held in place when used.
    • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
  3. Lenovo IdeaPad Y500 Fan Replacement: Schritt 3, Bild 1 von 1
    • Gently pull battery away from the computer while holding open the lock.
  4. Lenovo IdeaPad Y500 Fan Replacement, Touchpad: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Y500 Fan Replacement, Touchpad: Schritt 4, Bild 2 von 2
    • Remove a total of 8 screws.
    • Red circles are m2.5 x 10 mm flathead screws.
    • Orange circles m2 x 3mm flathead screws.
    • Yellow circle is m2.5 x 4mm flathead screw.
  5. Lenovo IdeaPad Y500 Fan Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 5, Bild 3 von 3
    • Flip up black tabs at the ends of each cable.
    • With fingers, gently remove the cables underneath from their ports.
  6. Lenovo IdeaPad Y500 Fan Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 6, Bild 3 von 3
    • By unlatching the sides and pulling up, remove the top case from the device.
    • Casing is fragile, be careful not to twist when pulling up.
  7. Lenovo IdeaPad Y500 Fan Replacement, Keyboard: Schritt 7, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement, Keyboard: Schritt 7, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement, Keyboard: Schritt 7, Bild 3 von 3
    • Unlock the battery latch by pulling it up.
    • It should reveal red underneath when it's unlocked.
  8. Lenovo IdeaPad Y500 Fan Replacement: Schritt 8, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 8, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 8, Bild 3 von 3
    • Push the latch down and then hold in position.
    • Pull the optical drive out.
  9. Lenovo IdeaPad Y500 Fan Replacement: Schritt 9, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 9, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 9, Bild 3 von 3
    • Remove nine screws with a Phillips #1 screwdriver.
  10. Lenovo IdeaPad Y500 Fan Replacement: Schritt 10, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 10, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 10, Bild 3 von 3
    • Pull up on the loosened cover to remove.
    • Remove two screws with a Phillips #1 screwdriver.
  11. Lenovo IdeaPad Y500 Fan Replacement: Schritt 11, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 11, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 11, Bild 3 von 3
    • Pull the tab straight to the left until part releases.
    • Lift up the part to remove completely.
  12. Lenovo IdeaPad Y500 Fan Replacement: Schritt 12, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 12, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 12, Bild 3 von 3
    • To release the DIMM, pull the tabs on either side away from each other simultaneously.
    • The DIMM will pop out on its own.
  13. Lenovo IdeaPad Y500 Fan Replacement: Schritt 13, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 13, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 13, Bild 3 von 3
    • To disconnect the Wi-Fi cables, use a spudger to gently push up under them.
    • Wi-Fi cables are delicate.
  14. Lenovo IdeaPad Y500 Fan Replacement: Schritt 14, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 14, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 14, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the two screws.
    • Once screws are out, the card will just pop out.
  15. Lenovo IdeaPad Y500 Fan Replacement: Schritt 15, Bild 1 von 1
    • Remove three screws using a Phillips #1 screwdriver.
  16. Lenovo IdeaPad Y500 Fan Replacement: Schritt 16, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 16, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 16, Bild 3 von 3
    • With the laptop upside down, open slightly.
    • To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
    • You will not be able to pull the keyboard completely away. The cables are still connected to the laptop.
  17. Lenovo IdeaPad Y500 Fan Replacement: Schritt 17, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 17, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 17, Bild 3 von 3
    • To release the cables, use the spudger to push both ends on the side of the cable.
    • Gently pull the cables up to disconnect.
  18. Lenovo IdeaPad Y500 Fan Replacement: Schritt 18, Bild 1 von 2 Lenovo IdeaPad Y500 Fan Replacement: Schritt 18, Bild 2 von 2
    • Pull the keyboard up and away from the laptop to remove it.
  19. Lenovo IdeaPad Y500 Fan Replacement, Motherboard: Schritt 19, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement, Motherboard: Schritt 19, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement, Motherboard: Schritt 19, Bild 3 von 3
    • Peel up the black tab and remove the tape completely.
    • Remove the cable revealed underneath while pulling up the tape.
    • When reassembled, you will have to stick the tape back down in its original location in order to reinsert the cable.
  20. Lenovo IdeaPad Y500 Fan Replacement: Schritt 20, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 20, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 20, Bild 3 von 3
    • Flip the laptop back over.
    • Gently pull the cable free by pulling up.
  21. Lenovo IdeaPad Y500 Fan Replacement: Schritt 21, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 21, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 21, Bild 3 von 3
    • Peel back the black tape.
    • Gently pull out both cables revealed underneath from their sockets.
    • When reassembling, you will have to paste the tape back over the cables again.
  22. Lenovo IdeaPad Y500 Fan Replacement: Schritt 22, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 22, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 22, Bild 3 von 3
    • By gently pulling up, remove the final cable.
  23. Lenovo IdeaPad Y500 Fan Replacement: Schritt 23, Bild 1 von 2 Lenovo IdeaPad Y500 Fan Replacement: Schritt 23, Bild 2 von 2
    • Pull motherboard down, away from the case, while lifting the base of the case up.
  24. Lenovo IdeaPad Y500 Fan Replacement, Fan: Schritt 24, Bild 1 von 1
    • With a Phillips #1 screwdriver, loosen the six screws.
    • These screws are spring loaded. They will not come completely out. They only need to be loosened.
  25. Lenovo IdeaPad Y500 Fan Replacement: Schritt 25, Bild 1 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 25, Bild 2 von 3 Lenovo IdeaPad Y500 Fan Replacement: Schritt 25, Bild 3 von 3
    • Gently lift the fan up to remove.
Abschluss
Tatum Hennige
687 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S1-G2, Cardinal Spring 2019 Mitglied von UW Tacoma, Team S1-G2, Cardinal Spring 2019
UWT-CARDINAL-S19S1G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,378
