Einleitung
This guide is to be used to remove your motherboard from your IdeaPad Y500.
Was du brauchst
Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
Unlock the battery latch by pulling it up.
It should reveal red underneath when it's unlocked.
Pull up on the loosened cover to remove.
Remove two screws with a Phillips #1 screwdriver.
Pull the tab straight to the left until part releases.
Lift up the part to remove completely.
To release the DIMM, pull the tabs on either side away from each other simultaneously.
The DIMM will pop out on its own.
Using a Phillips #1 screwdriver, remove the two screws.
Once screws are out, the card will just pop out.
With the laptop upside down, open slightly.
To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
To release the cables, use the spudger to push both ends on the side of the cable.
Gently pull the cables up to disconnect.
Remove a total of 8 screws.
Red circles are m2.5 x 10 mm flathead screws.
Orange circles m2 x 3mm flathead screws.
Yellow circle is m2.5 x 4mm flathead screw.
Flip up black tabs at the ends of each cable.
With fingers, gently remove the cables underneath from their ports.
Peel up the black tab and remove the tape completely.
Remove the cable revealed underneath while pulling up the tape.
Peel back the black tape.
Gently pull out both cables revealed underneath from their sockets.
Pull motherboard down, away from the case, while lifting the base of the case up.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
