Zum Hauptinhalt wechseln
Lenovo IdeaPad Y510P Hard Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad Y510P Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Locate the two battery locks on the bottom of the computer.
    • Slide the left battery lock to the left, exposing the red indicator.
    • While holding the right battery lock to the right, gently pull the battery out.
    • Fully discharge the laptop by pressing and holding the power button for 10 seconds after removing the battery. This ensures that there is no electricity in the laptop itself.
  2. Lenovo IdeaPad Y510P Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaPad Y510P Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Unscrew all nine of the backplate screws with a JI head screwdriver.
    • Carefully pry the backplate off of the laptop.
    • If there is resistance, check for any remaining screws.
  3. Lenovo IdeaPad Y510P Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Gently lift and remove the hard drive.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 37
Letzte 30 Tage: 105
Insgesamt: 4,191
