Einleitung
The top assembly contains the keyboard and trackpad. Removing it allows access to the logic board, battery, and RAM.
Was du brauchst
Position the laptop so that the bottom enclosure is facing upward.
Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
Use an opening tool to carefully pry up the rubber pads.
Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
Flip the laptop over and swing open the display.
Lift the edge of the keyboard closest to the trackpad up.
Carefully disconnect keyboard ribbon cable from the laptop.
Remove the keyboard.
Grab the front edge of the top assembly and lift it up carefully.
Gently slide the three ribbon cables out of their slots.
Remove the top assembly completely by pulling it off of the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
