Einleitung
Replacing the Wi-Fi card is a semi-invasive repair and should only be attempted if your computer is not recognizing a wireless antenna. This symbol in the hot-bar on the bottom right that normally indicates a wireless connection will appear to be a small box with a wire coming out.
NOTE: It is VERY important to make sure to check that Wi-Fi is NOT DISABLED on your device before attempting this repair, as this may be the problem and a repair attempt will only increase the chances of causing damage.
Was du brauchst
Remove the ten screws on the back panel of the laptop using the T4 Torx screwdriver.
Remove the back panel from the device.
Use blue the opening tool to gently further separate the keyboard bezel.
Carefully apply pressure to the keyboard. It should easily pop out.
To remove the keyboard bezel (black cover containing the mouse pad) remove the five screws using the Phillips #0 screwdriver.
Unplug the connections from motherboard, including the mouse and keyboard connections.
Remove the ribbon cable covering the card by disconnecting the two connection points on either side.
Lift up the bottom right lever on the WiFi card metal bracket.
Slide the bracket to the left to disconnect it from the 4 plastic legs holding it down.
