Zum Hauptinhalt wechseln
Lenovo IdeaPad Z570 Charging Port Replacement
Was du brauchst
  1. Lenovo IdeaPad Z570 Charging Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 4, Bild 2 von 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Charging Port Replacement, Disc Drive: Schritt 5, Bild 1 von 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 7, Bild 2 von 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 8, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 8, Bild 2 von 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: Schritt 9, Bild 1 von 3 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: Schritt 9, Bild 2 von 3 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: Schritt 9, Bild 3 von 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 10, Bild 1 von 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 11, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 11, Bild 2 von 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 12, Bild 1 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 12, Bild 2 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 12, Bild 3 von 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 13, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 13, Bild 2 von 2
    • Pull the keyboard out from the terminal block.
  14. Lenovo IdeaPad Z570 Charging Port Replacement, Charging Port: Schritt 14, Bild 1 von 1
    • Place the laptop on the backside with the battery facing away from you.
    • Remove the eleven 7 mm screws located around the edge of the backside of the laptop using the Phillips #0 screwdriver.
  15. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 15, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 15, Bild 2 von 2
    • Remove the two 3 mm screws located in the battery slot using the Phillips #0 screwdriver.
    • Orientate the laptop back to its original position.
  16. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 16, Bild 1 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 16, Bild 2 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 16, Bild 3 von 3
    • There are three connection strips similar to the one in guide three.
    • Remove the three connection strips in the same manner as the keyboard replacement guide.
  17. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 17, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 17, Bild 2 von 2
    • Remove the two 7mm screws found on the right side of the silver plating on the laptop using the Phillips #0 screwdriver.
  18. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 18, Bild 1 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 18, Bild 2 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 18, Bild 3 von 3
    • Wedge the opening tool between the ethernet jack and the speaker to pry of the front plate of the laptop.
  19. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 19, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 19, Bild 2 von 2
    • Remove the one 7 mm screw located at the top left corner of the laptop near the charging port using the Phillips #0 screwdriver.
  20. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 20, Bild 1 von 2 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 20, Bild 2 von 2
    • There are two connection terminals on the upper right hand corner of the fan.
    • Remove the connection terminal marked with a blue stripe.
  21. Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 21, Bild 1 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 21, Bild 2 von 3 Lenovo IdeaPad Z570 Charging Port Replacement: Schritt 21, Bild 3 von 3
    • Lift the metal plate enough to wedge your index finger and thumb to grip the charger port.
    • Remove the charging port from the device.
Abschluss
Mya DeSantos
318 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Mitglied von UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 1,633
