Zum Hauptinhalt wechseln
Lenovo IdeaPad Z570 Keyboard Replacement
Was du brauchst
  1. Lenovo IdeaPad Z570 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Keyboard Replacement, Disc Drive: Schritt 5, Bild 1 von 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 8, Bild 1 von 2 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: Schritt 9, Bild 1 von 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: Schritt 9, Bild 2 von 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: Schritt 9, Bild 3 von 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 11, Bild 1 von 2 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 12, Bild 1 von 3 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 12, Bild 2 von 3 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 12, Bild 3 von 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 13, Bild 1 von 2 Lenovo IdeaPad Z570 Keyboard Replacement: Schritt 13, Bild 2 von 2
    • Pull the keyboard out from the terminal block.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Mya DeSantos
318 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Mitglied von UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 1,144
