Zum Hauptinhalt wechseln
Lenovo IdeaPad Z570 Screen Replacement
Was du brauchst
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: Schritt 2, Bild 1 von 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: Schritt 3, Bild 1 von 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Z570 Screen Replacement: Schritt 4, Bild 2 von 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Z570 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaPad Z570 Screen Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: Schritt 8, Bild 1 von 2 Lenovo IdeaPad Z570 Screen Replacement: Schritt 8, Bild 2 von 2
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: Schritt 9, Bild 1 von 2 Lenovo IdeaPad Z570 Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: Schritt 10, Bild 1 von 2 Lenovo IdeaPad Z570 Screen Replacement: Schritt 10, Bild 2 von 2
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: Schritt 11, Bild 1 von 3 Lenovo IdeaPad Z570 Screen Replacement: Schritt 11, Bild 2 von 3 Lenovo IdeaPad Z570 Screen Replacement: Schritt 11, Bild 3 von 3
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: Schritt 12, Bild 1 von 1
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: Schritt 13, Bild 1 von 3 Lenovo IdeaPad Z570 Screen Replacement: Schritt 13, Bild 2 von 3 Lenovo IdeaPad Z570 Screen Replacement: Schritt 13, Bild 3 von 3
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Daniel Lopes
610 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Mitglied von UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,039
