Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the digital board.
  1. Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Remove the following two screws: M3.0 x 3.0 mm #00 phillips screws (black)
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Once it is unscrewed, remove the rear cover This may take a little force to get off but with enough force it should pop right off Use a blue opening tool to pry it open
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  5. Use the tweezer tool to flip up the three small plastic locks attached to the digital board. Then, slide newly exposed ribbons out.
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  6. Remove the following two screws: M5.3 x 1.75 mm #00 phillips screws (silver)
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  7. Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Brian
565 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-19, Regan Spring 2014 Mitglied von Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 6
Insgesamt: 2,865
