Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the system board
  1. Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Remove SD card if present. Remove two black 3mm Phillips #00 screws.
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing. Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Remove seven black 3mm Phillips #00 screws. The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Now you can take the battery out in order to either replace it or continue disassembling the device. Now you can take the battery out in order to either replace it or continue disassembling the device.
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Remove two black 3mm Phillips #00 screws. Remove three silver 1.8 mm Phillips #00 screws. Remove three silver 1.8 mm Phillips #00 screws.
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Use tweezers to flip up the small black plastic locks on all four connections. Carefully remove each of the exposed ribbons. Carefully remove each of the exposed ribbons.
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing. Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector. Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Disconnect the HDMI connection with the system board Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free. Slide out the system board from its housing tab on the upper right corner.
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Kyle
581 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-19, Regan Spring 2014 Mitglied von Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 1,425
