Zum Hauptinhalt wechseln
Lenovo IdeaTab S2109A-F Battery Replacement
Was du brauchst
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaTab S2109A-F Battery Replacement: Schritt 2, Bild 2 von 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Caelen
228 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 17-3, Watkins Winter 2015 Mitglied von USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare zur Anleitung
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - Antwort
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 1,611
