Einleitung
The following guide details the necessary steps that you have to follow in order to replace the vibration motor for the Lenovo IdeaTab S6000.
Was du brauchst
Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
Go all around the casing, prying the screen away from the backing with the spudger.
It will make a popping sound each time one of the lock tabs is disconnected.
Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
Remove the battery by grabbing the tab shown and pulling up.
The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
