Zum Hauptinhalt wechseln
Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement
Was du brauchst
Einführungsvideo
  1. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all 11 screws from the base of the laptop.
  2. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: Schritt 2, Bild 1 von 1
    • Once the screws have been removed, lift the base out of the laptop. You may need something pointy to pry it up.
  3. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: Schritt 3, Bild 2 von 2
    • Next disconnect the battery
  4. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: Schritt 4, Bild 1 von 1
    • Next remove the four screws holding the battery in place.
  5. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: Schritt 5, Bild 2 von 2
    • And your all done.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick Myers
3.410 Reputation
22 Anleitungen geschrieben
Ein Kommentar
YOU HAVE TO REMOVE THE KEYBOARD. First, the keyboard is glued with two sided tape so it feels like you are breaking something getting it off. It also has clips all around don't try to undo the bottom until last. Second, there are 3 screws under the keyboard that need to be removed. The third screw was hidden under a Lenovo label, thanks Lenovo. Thirdly, there is no need to disconnect the keyboard harness.
panellockout - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 9,242
