Einleitung
This guide will teach you to replace the battery of the Lenovo Ideapad 110S-11IBR, if faulty or to service another part.
Was du brauchst
Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Remove the two pieces of tape that are holding the battery down.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Great instructions but where can you by a replacement battery? I can’t find one anywhere.
