Zum Hauptinhalt wechseln
Lenovo Ideapad 110S-11IBR Speaker Replacement
Was du brauchst
  1. Lenovo Ideapad 110S-11IBR Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 2, Bild 2 von 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 3, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 5, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Speaker Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Use your fingers to gently remove the speaker connector from its socket.
  7. Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 7, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the four 4mm Phillips screws.
  8. Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 8, Bild 1 von 1
    • Pull the right speaker carefully under the ribbon cable.
  9. Lenovo Ideapad 110S-11IBR Speaker Replacement: Schritt 9, Bild 1 von 1
    • Lift the the left speaker to finish.
Abschluss
Andy Rangel
119 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 678
