Zum Hauptinhalt wechseln
Lenovo Ideapad 110S-11IBR Touchpad Replacement
Was du brauchst
  1. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 2, Bild 2 von 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 3, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 5, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Touchpad: Schritt 6, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
  7. Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Remove the clicker assembly.
  8. Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 8, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening tool to remove the touch pad.
    • Time must be taken to work the adhesive without causing damage to the touch pad.
Abschluss
Samaa Aldar
181 Reputation
2 Anleitungen geschrieben
IUPUI, Team S11-G11, Wilson Spring 2019 Mitglied von IUPUI, Team S11-G11, Wilson Spring 2019
IUPUI-WILSON-S19S11G11
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
i appreciate the tear down. I would like to see the screws that came out of the holes instead of empty screw holes though.
daldal - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 1,286
