Einleitung
This guide aims to teach you how to replace the USB 2.0 and 3.5 mm headphone ports of the Lenovo Ideapad 110S-11IBR.
Was du brauchst
Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Remove the two pieces of tape that are holding the battery down.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
