Zum Hauptinhalt wechseln
Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Wi-Fi Card: Schritt 6, Bild 1 von 1
    • Locate the Wi-Fi card.
  7. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the two wires that are connected to the Wi-Fi card by gently pulling them up.
  8. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 8, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the one 4mm screw keeping the card in place.
  9. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 9, Bild 1 von 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: Schritt 9, Bild 2 von 2
    • Gently pull the Wi-Fi card out of place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 1,252
