Einleitung
A comprehensive how-to guide on replacing the motherboard in a Lenovo Ideapad 120s-14IAP. The motherboard replacement will fix most operational issues with your laptop. If possible, reduce the amount of contact with components of the motherboard during installation.
Was du brauchst
Orient the laptop so the top is laying flat on your work surface.
Remove ten 1.5mm Torx T5 screws from the back of the laptop.
Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
Remove the back cover.
Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
Using tweezers, disconnect the speaker on the left from the USB daugterboard.
Remove two 2.5 mm Phillips #0 screws from the daughterboard.
Remove the daughterboard from the laptop.
Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
Pull on the plastic film to remove the display connection cable.
Using tweezers, disconnect the connections for the right speaker.
Using tweezers, disconnect the connections for the battery.
Using tweezers, disconnect the connections for the CMOS battery.
Remove the wireless card by disconnecting the two antenna cables and removing the 2.5 mm Phillips #0 screw.
Remove seven 2.5 mm Phillips #0 screws from the motherboard.
Slide the motherboard out of the laptop chassis.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
