Einleitung
In this short guide, guidance will be provided on replacing the fan in the Lenovo 310-15IKB Laptop., in case it is damaged for is simply non-functional.
Was du brauchst
Flip the laptop over so the back panel is facing up.
Remove the single 6 mm screw from the L-shaped panel using a Phillips #0 screwdriver.
Gently unplug the connector for the fan from the underside by pulling it gently.
Use an opening tool to remove the keyboard cover panel, exposing the motherboard and fan.
Remove the single 3 mm screw holding the fan in place using a Phillips #0 screwdriver.
Remove the fan by pulling it away from the motherboard and then upwards out of the laptop.
To reassemble your device, follow these instructions in reverse order. Be careful to align the fan screw holes in place.
