Einleitung
This guide will show you how to disassemble the back panel for the device.
This guide is also a prerequisite guide for other hardware part replacement.
Was du brauchst
Remove the single 7 mm Phillips #1 screw securing the optical drive.
Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
How Is solved Twisted screw and broken inside the frame
For laptop ip520
