Zum Hauptinhalt wechseln
Lenovo Ideapad 320-15ABR Fan Replacement
Was du brauchst
  1. Lenovo Ideapad 320-15ABR Fan Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 2, Bild 1 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 2, Bild 2 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 2, Bild 3 von 3
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 3, Bild 1 von 2 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 3, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 4, Bild 1 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 4, Bild 2 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 5, Bild 1 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 5, Bild 2 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Fan Replacement, Battery: Schritt 6, Bild 1 von 1
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 7, Bild 1 von 2 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery.
  9. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: Schritt 9, Bild 1 von 2 Lenovo Ideapad 320-15ABR Fan Replacement, Fan: Schritt 9, Bild 2 von 2
    • Disconnect black and grey wires by simply giving them a light tug.
  10. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 10, Bild 1 von 1
    • Remove the 6mm Phillips #1 screw connecting the fan to the laptop.
  11. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 11, Bild 1 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 11, Bild 2 von 3 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 11, Bild 3 von 3
    • Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
  12. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 12, Bild 1 von 1
    • Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
  13. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 13, Bild 1 von 2 Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 13, Bild 2 von 2
    • Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
  14. Lenovo Ideapad 320-15ABR Fan Replacement: Schritt 14, Bild 1 von 1
    • Replace the new fan.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 5,769
