Einleitung
The purpose of this guide is to demonstrate how to replace the battery of your Lenovo Ideapad 350-15IAP. This replacement guide is very simple and requires very little technical knowledge to complete. In summary, you will be using a Phillip’s head screwdriver to remove the case of the laptop. The battery will be immediately exposed and can be removed by simply removing four screws.
Was du brauchst
Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
Remove the CD drive.
Lift up the cover using the opening tool on different spots along the side of the laptop.
Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
