Zum Hauptinhalt wechseln
Lenovo Ideapad 320-15IAP Motherboard Replacement
Was du brauchst
  1. Lenovo Ideapad 320-15IAP Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Unscrew thirteen 6.5mm screws from the back panel with the Phillips #0 screwdriver.
    • Pull the CD tray out with the opening tool once all screws are removed.
    • Use the opening tool to pull the case off the laptop by prying up the back panel along the edges of the computer.
  2. Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 2, Bild 1 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 2, Bild 2 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Unscrew four 4.5mm screws from the screen brackets using a Phillips #0 screwdriver.
    • Gently pull the wire protector from the back of the computer. You may hear cracking sounds but this is normal, as the locks are disengaging as you pull.
  3. Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 3, Bild 1 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 3, Bild 2 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the display cable by lifting the black tab of the ZIF connector with the opening tool and gently pulling out the cable.
    • Disconnect the two coaxial cables on the WiFi card by gently pulling up on the wires.
    • Lift up the screen brackets by prying upwards on them with an opening tool.
    • It may help to pry up on both brackets simultaneously, but only the righthand one needs to be lifted so that the motherboard can be removed from beneath it.
  4. Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 4, Bild 1 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 4, Bild 2 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Unscrew four 3mm silver screws on the motherboard using the Phillips #0 screwdriver.
    • Unscrew the single 6mm black screw with a Phillips #0 screwdriver.
    • Unscrewing one of the silver screws will force the WiFi card to pop up. If your new motherboard doesn't come with its own WiFi card, you should unplug the card and install it into your new motherboard.
  5. Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 5, Bild 1 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 5, Bild 2 von 3 Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the six ribbon cables by lifting up the locking black tabs from their ZIF connectors with a spudger, then gently pulling out the cables.
  6. Lenovo Ideapad 320-15IAP Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the motherboard, being sure that no cables are being pulled or snagged in the process.
    • If your new motherboard did not come with RAM sticks installed, you may need to transfer over your old RAM before reinstalling. Check out this guide to see how it's done.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I used this for the IdeaPad 330. Worked pretty much the same except in step 2 I broke all the tabs on the wire cover. The cracking sounds definitely were not normal for me on this model.
Glen Meiring - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 45
Insgesamt: 1,518
