Einleitung
Use this guide to replace the back panel of the Lenovo IdeaPad 320-17IKB.
The back panel is the bottom plastic piece of the laptop and it often takes the most wear and tear over the years when the laptop is being used. The back panel can often crack, which can result in damages to the hardware inside the computer.
Before using this guide, check out the Lenovo IdeaPad 320-17IKB Troubleshooting page for more helpful information in diagnosing your device.
Use caution when lifting the back panel off the laptop to not damage any hardware.
Was du brauchst
Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
Lay both sides of the laptop next to each other.
2 weitere Personen haben diese Anleitung absolviert.
