Zum Hauptinhalt wechseln
Lenovo Ideapad 320-17IKB RAM Replacement
Was du brauchst
  1. Lenovo Ideapad 320-17IKB RAM Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo Ideapad 320-17IKB RAM Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad 320-17IKB RAM Replacement: Schritt 2, Bild 2 von 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
    Frag FixBot
  3. Lenovo Ideapad 320-17IKB RAM Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
    Frag FixBot
  4. Lenovo Ideapad 320-17IKB RAM Replacement: Schritt 4, Bild 1 von 2 Lenovo Ideapad 320-17IKB RAM Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
    Frag FixBot
  5. Lenovo Ideapad 320-17IKB RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • The RAM is located on the right side of the motherboard above the battery.
    Frag FixBot
  6. Lenovo Ideapad 320-17IKB RAM Replacement: Schritt 6, Bild 1 von 2 Lenovo Ideapad 320-17IKB RAM Replacement: Schritt 6, Bild 2 von 2
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it to release the RAM stick.
    • The RAM stick will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
    • Slide the RAM stick out from the memory module slot.
    • When installing new RAM, slide it into the port at the same angle it was removed and press down until it clicks into place.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 30
Insgesamt: 470
