Einleitung
If the laptops speakers need to be replaced, this guide will be helpful in order to walk you through the process.
Was du brauchst
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
Using a plastic opening tool, make your way around the edge of the laptop.
There is a visible line between the bottom shell of the laptop and the laptop body itself.
Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
Locate the speaker unit at the top left hand corner of the Flex 15.
Using the screwdriver (PH1 bit), remove the (50 mm) screws on either side of the speaker unit.
There is a small white socket which a cable of the speakers is plugged into.
Pull the wire off by pulling either sides of the black header (do not pull the wire directly as it could break off).
The speaker can be removed carefully.
