Einleitung
Is the back panel to your device cracked or broken? Consider using this guide to replace the back panel of your laptop.
Was du brauchst
Remove the nine 6 mm screws using a T5 Torx Screwdriver.
Remove the two 10 mm screws using a T5 Torx Screwdriver.
Use a plastic opening tool to carefully pry off the back cover.
Remove the back cover.
Fast fertig!
Ziellinie
