Einleitung
If the laptop is loud, sounds irregular, and the bottom is hot, use this guide to replace your cooling fan.
Was du brauchst
Remove the nine 6 mm screws using a T5 Torx Screwdriver.
Remove the two 10 mm screws using a T5 Torx Screwdriver.
Use a plastic opening tool to carefully pry off the back cover.
Remove the back cover.
Pull black wire and gray wire away from cooling fan clips using the tweezers.
Pull out the cooling fan from where it is attached and pull it up until you see where the wire is attached to the motherboard. Using the iFixit Opening Tools, detach the connector.
Eine weitere Person hat diese Anleitung absolviert.
