Einleitung
If you are unable to move the mouse and it is overly sensitive, use this guide to replace your touchpad.
Was du brauchst
Remove the nine 6 mm screws using a T5 Torx Screwdriver.
Remove the two 10 mm screws using a T5 Torx Screwdriver.
Use a plastic opening tool to carefully pry off the back cover.
Remove the back cover.
Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
Open the laptop and, with the assistance of the iFixit blue plastic tool, guide the touch pad through, it should come out on its own.
