Zum Hauptinhalt wechseln
Lenovo Ideapad S415 Touch Fan Replacement
Was du brauchst
  1. Lenovo Ideapad S415 Touch Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 2, Bild 1 von 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 3, Bild 1 von 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 4, Bild 1 von 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 5, Bild 1 von 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Fan Replacement, Fan: Schritt 6, Bild 1 von 2 Lenovo Ideapad S415 Touch Fan Replacement, Fan: Schritt 6, Bild 2 von 2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five black screws.
  7. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 7, Bild 1 von 2 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 7, Bild 2 von 2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Using the Phillips #0 screwdriver, remove all three silver screws.
  8. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 8, Bild 1 von 3 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 8, Bild 2 von 3 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 8, Bild 3 von 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your fingers.
  9. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 9, Bild 1 von 3 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 9, Bild 2 von 3 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 9, Bild 3 von 3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 10, Bild 1 von 2 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 10, Bild 2 von 2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 11, Bild 1 von 2 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 11, Bild 2 von 2
    • Locate the silver 6mm screw on the top of the fan
    • Locate the silver 4mm screw on the bottom of the fan
    • Use a Phillips #0 screwdriver to remove both screws.
  12. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 12, Bild 1 von 2 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 12, Bild 2 von 2
    • Locate the fan power connector.
    • Use a spudger or your hands to disconnect the fan power connector from its port.
  13. Lenovo Ideapad S415 Touch Fan Replacement: Schritt 13, Bild 1 von 2 Lenovo Ideapad S415 Touch Fan Replacement: Schritt 13, Bild 2 von 2
    • Once the fan power connector is disconnected, lift up the bronze heatsink and pull the wires out from underneath it.
    • Lift up the fan and pull free.
Abschluss
Alexandria
363 Reputation
2 Anleitungen geschrieben
UC Davis, Team S20-G5, Lore Winter 2019 Mitglied von UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 190
