Einleitung
If your computer will not turn on, there may be a problem with the hard drive. This guide will help replace the hard drive in your laptop, and is moderately difficult. Make sure to have a Phillips #0 screwdriver on hand to achieve the steps in this guide.
Was du brauchst
Flip laptop over bottom side up.
Locate the two battery release switches.
Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
Locate the five black screws on the back.
Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
Locate the three silver screws underneath the battery.
Use the Phillips #0 screwdriver to remove all three 4 mm screws.
Locate the four rubber stoppers near each corner of the laptop.
Open up the stopper with your hands.
Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
Locate the hard drive.
Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
