Zum Hauptinhalt wechseln
Lenovo Ideapad Yoga 2 11 Trackpad Replacement
Was du brauchst
  1. Lenovo Ideapad Yoga 2 11 Trackpad Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 2, Bild 2 von 2
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Trackpad Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo Ideapad Yoga 2 11 Trackpad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 5, Bild 1 von 3 Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 5, Bild 2 von 3 Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 6, Bild 1 von 2 Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 6, Bild 2 von 2
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 7, Bild 1 von 2 Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 7, Bild 2 von 2
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
  8. Lenovo Ideapad Yoga 2 11 Trackpad Replacement, Trackpad: Schritt 8, Bild 1 von 1
    • After removing the battery, locate the trackpad of your laptop.
  9. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 9, Bild 1 von 2 Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 9, Bild 2 von 2
    • Unscrew 7x 2mm screws holding touchpad in place.
  10. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 10, Bild 1 von 1
    • Lift up the plastic cover over the ribbon cable.
  11. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 11, Bild 1 von 1
    • Gently tug ribbon cable from its position.
  12. Lenovo Ideapad Yoga 2 11 Trackpad Replacement: Schritt 12, Bild 1 von 1
    • Lift trackpad from the computer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Andria Chen
624 Reputation
5 Anleitungen geschrieben
UC Santa Barbara, Team S1-G5, Weedon Fall 2017 Mitglied von UC Santa Barbara, Team S1-G5, Weedon Fall 2017
UCSB-WEEDON-F17S1G5
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 784
