Zum Hauptinhalt wechseln
Lenovo Ideatab A1107 Back Cover Replacement
Was du brauchst
  1. Lenovo Ideatab A1107 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 2 Lenovo Ideatab A1107 Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Back Cover Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideatab A1107 Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 461
