Einleitung
The Lenovo Ideatab A1107 Battery Replacement guide will show users how to safely remove the battery from the Lenovo Ideatab A1107. Included in the guide are the proper tools needed to complete the replacement, as well as photos with mark-ups.
Was du brauchst
Insert a plastic opener in-between the black back panel and the silver body of the tablet.
Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
Wedge a plastic opening tool in between the battery and the internal components of the device.
Use the plastic opener tool to remove the battery from its casing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
