Zum Hauptinhalt wechseln
Lenovo Ideatab A1107 Speaker Replacement
Was du brauchst
  1. Lenovo Ideatab A1107 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 2 Lenovo Ideatab A1107 Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo Ideatab A1107 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
  4. Lenovo Ideatab A1107 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers or hands to disconnect speaker wires.
  5. Lenovo Ideatab A1107 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Use tweezers to pull the speaker off of the casing.
  6. Lenovo Ideatab A1107 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the speaker component from the rubber casing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 147
