Einleitung
This guide shows a step by step process on how to replace the front camera on a Lenovo Ideatab S6000. The front camera would need to be replaced if the front camera function is not working properly on the tablet. If the screen is cracked or shattered, be sure to wear proper protective equipment and make sure device is turned off before any repair is started.
Was du brauchst
Remove the screws from both of the spots that were covered with a Phillips #000 screwdriver.
Go all around the casing, prying the screen away from the backing with the spudger.
Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
Flip up the black tab on each connector.
Pull the ribbon cables out using a plastic opening tool.
Gently remove the front camera by pulling the ribbon connector out with a plastic opening tool.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
