Zum Hauptinhalt wechseln
  1. Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
  2. Remove the screws from both of the spots that were covered.
    • Remove the screws from both of the spots that were covered.
  3. DO NOT USE A METAL TOOL FOR THIS.
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Jetzt kaufen
    iPhone X Fix Kits
    Jetzt kaufen
  5. Pull off the plastic that is covering the battery cable.
    • Pull off the plastic that is covering the battery cable.
  6. Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it. Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  7. Remove the battery by grabbing the tab shown and pulling up.
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
  8. Gently lift up on the metal connector plate.
    • Gently lift up on the metal connector plate.
  9. Push against the camera from all sides to loosen it from its position. NOTE: The camera is connected by glue, so take your time, it will come out.
    • Push against the camera from all sides to loosen it from its position.
    • NOTE: The camera is connected by glue, so take your time, it will come out.
    • If you wish to replace the camera simply plug in the new camera, and follow the guide in reverse.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Josiah Speed
933 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 10-4, Brown Fall 2014 Mitglied von USF Tampa, Team 10-4, Brown Fall 2014
USFT-BROWN-F14S10G4
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 691
