Zum Hauptinhalt wechseln
Lenovo Legion 5-15ACH6 SSD Replacement
Was du brauchst
  1. Lenovo Legion 5-15ACH6 SSD Replacement, SSD: Schritt 1, Bild 1 von 1
    • Prepare your work area on a flat surface.
    • Lay your laptop down with the back case facing up.
  2. Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 2, Bild 1 von 1
    • Use a Philips #1 screwdriver to remove the six 11.1 mm on the back of the device.
    • Use a Philips #00 screwdriver to remove the four 4.1 mm screws on the back case.
  3. Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 3, Bild 1 von 3 Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 3, Bild 2 von 3 Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 3, Bild 3 von 3
    • Starting from the back of the laptop slide your opening tool between the bottom cover and laptop chassis.
    • Run the opening tool along the seam to separate the bottom cover from the chassis.
    • Remove the bottom cover and place to the side.
  4. Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 4, Bild 1 von 3 Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 4, Bild 2 von 3 Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 4, Bild 3 von 3
    • To disconnect the battery cable safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
    • Touching any electrical component with the battery plugged in can result in damage to the motherboard.
  5. Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 5, Bild 1 von 2 Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 5, Bild 2 von 2
    • Remove the three 4.1mm Phillips #00 screws holding the metal shield in place.
    • Remove the metal shield and place it to the side.
  6. Lenovo Legion 5-15ACH6 SSD Replacement: Schritt 6, Bild 1 von 1
    • Remove the single 4.1 mm Philips #00 screw holding the SSD in place.
    • Pull the SSD out and away from the socket.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
CSU Los Angeles, Team 12-5, Ribeiro Fall 2023 Mitglied von CSU Los Angeles, Team 12-5, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S12G5
3 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 87
Insgesamt: 417
